hellbilly75
Ok, so I have an hk power module to provide voltage to a pixhawk. This thing has xt60 connectors and fairly small wire. My setup at 100% could pull 106 amps. I know I probably won't ever draw that much current but It's possible none the less. Could I make a heavier battery connection harness and also attach the power module to the pdb to utilize the reduced voltage for the pixhawk? I know the current info the pixhawk can read probably wouldn't work since the current wouldn't be passing through but would it still read voltage ok? Or am I way off base?
