Hello, I have been testing with my recently acquired Pixhawk Autopilot for my Quadcopter. Here is my current components on the flight vehicle:
Frame: HobbyKing H-Copter H4-650
ESC's: RCTimer 45A NFS/Opto ESC
Motors: RCTimer 5010-620KV
Propellers: 10x4.5''
AP: Pixhawk PX4FMU
RC Remote: Spectrum DX8
We used QGroundControl to load the TBS Discovery Frame (H-Frame) configuration onto the Autopilot. We calibrated the ESC's and have tested the response of the system similar to that mentioned
in http://diydrones.com/forum/topics/arducopter-tuning-guide . We then flew the Quadcopter with the default gains of the TBS H-Frame and it rotated about the yaw axis continuously.
We then saw that as the throttle increased the built in magnetometer of the Pixhawk started seeing a slight rotation due to EMI, thus we thought it might be compensating for it. After viewing
https://groups.google.com/forum/#!topic/px4users/TbXFZf4EKDc , we adjusted the input to the Kalman Filter
EKF RC2 100 -> 1000000
to try and eliminate the interference. The problem in yaw still persisted.
The maximum attitude angles were adjusted accordingly but the response in pitch and roll seemed suitable for flight.
MC_MAN_P_MAX 35 -> 15
MC_MAN_R_MAX-35 > 15
However, when flown the Quadcopter continued to rotate about the yaw axis almost in a cyclic nature.
Initially, we thought it was the ESC's calibration that was a problem, we re-calibrated and the problem persisted. We then thought of increasing the proportional gain P for the Yaw Rate and the Yaw to try and compensate for yaw disturbance faster, the behavior remained the same after the flight test.
YAWRATE_P 0.28 -> 1
YAW_P 2.8 ->10
YAWRATE_MAX 120 -> 10
We then limited the max manual angles as a last attempt:
ACRO_Y_MAX 120 -> 10
MAN_Y_MAX 120 -> 10
MAN_P_MAX 35 -> 15
MAN_R_MAX 35 - 15
But the problem is still present. Please could anyone help with this problem. I thought it should work straight out of the box. I forgot to put the Micro-SD card in the APU to log the data during testing, so I do not have data but I will attach a video shortly.
AP: Pixhawk PX4FMU
YAWRATE_P 0.28 -> 1
YAW_P 2.8 ->10
MAN_Y_MAX 120 -> 10
MAN_P_MAX 35 -> 15
MAN_R_MAX 35 - 15
