Pixhawk Drifting
Chalagi
Pixhawk on my quad is finally air born and I have a drift problem. It will drift left and backwards at the same time I have used trim to try and correct the problem with no results. Any suggestions?
violetwolf
Could be a number of things. If it won't trim out at the tx then its on the craft. I'd suspect the FC was not properly calibrated for level.
Chalagi
Ok I will redo the level calibration and another problem is I can't change the Altitude Hold PID. When I do make change. I goes back to the same thing it was before I changed the number.
Chalagi
Well I did the re-calibration for level and with some tx trim I think I might have fixed the problem. Now for the other problem and that's the gps that I have redone no telling how many times and pixhawk accepted the numbers every time.
