Does anyone know what a coax 8 configuration hooking up 8 ESCs to the NAZA for a phantom X8 build? From the link the individual forgot to show the configuration picture.
Yes, with a coax 8 you use 8 ESCs all connected to the output end of the Naza, and you can choose in Naza Assistant the correct motor mixer (x8) so it knows which motors to fire.
You do need to install the props "upside down" on the bottom motors and reverse the motor direction because they will be spinning reversed when inverted.
Here's how you do it:
http://www.********.com/forums/showthread.php?t=1994272
R/
John
R/
John
