crayfellow
It sounds like the preferred chargers are iCharger (example iCharger 306B) and FMA PowerLab (example PowerLab 6). Naturally, everyone has their preference for what is best and how everything else is not best, but I'm wondering what is working for you.
Power supplies are obviously a major factor too, as more voltage means smaller current draw for equivalent power, and more power means faster charging and/or more batteries being charged at once in parallel. They can be bought off the shelf for top dollar, or you can grab a server-class computer power supply used and modify it for this purpose. Alternately, you could buy a few from someone who has already done that, or someone else, for a pretty reasonable price.
Battery connectors are also an issue. For example, you might like to use this to balance charge a bunch of batteries at once, but you'd need an adapter to go from deans to whatever you use for each (unless you use deans). There are alternatives (that one is for Anderson PowerPole, the connector I happen to use) but we'd need to make sure the balance plug uses the same layout as whatever charger you end up with.
These (or this) seem to solve the connector problem, right?
So, what works for you?
