Garrett_Gti_Dan
Hello guys. I found a king kong 12 a esc. Apparently, it does not have bec because it has opto. What is that? And will it work? Thanks
Sent from my iPad using Tapatalk
Great explanation Mr. Relish. When building my Tarot FY680 Pro, I chose OPTO ESCs and didn't know what they were and had to learn the hard way - thank God for the internet! Anyway, since I am using an APM 2.6 FC, I also wired in an APM power module to supply power to the FC. But I needed power for my Tarot two axis gimbal and video transmitter, so I bought a UBEC.Hi,
OPTO ESC's are used to isolate the Flight Computer from switching noise feeding back from the ESC. There is no direct electrical connection to the ESC switching electronics, an OPTO ISOLATOR on the ESC transfers the signal from the FC using light.
If you use OPTO ESC's, the FC needs it's 5v supply fed separately from the battery using a BEC voltage regulator board.
If you use non opto ESC's, then they will have an onboard BEC. You then don't need a separate BEC to power the FC
Connecting one ESC to the FC will power it. The remaining ESC's connections will require the red power wire being removed.
Some FC's don't like multiple BEC supplies.
Make sense ?
Mr Relish
