Octocopter multicopter heavy lifter DJI 43 inches diameter
labedatwo007
THIS IS A READY TO FLY OCTOCOPTER PROFESSIONALLY BUILD. IS BIG BIG BIG 43 INCHES IN DIAMETER AND IT CAN ALSO BE MODIFIED TO BE 33 INCHES IF YOU'D LIKE so as you can see comparing to the pic with the DX8. designed to lift a Canon 5D WITH 13-65 CARBON FIBER PROPS,WITH TWO SPARES)- same size as the famous Droidwork Sky Jib 8. AVROTOR MOTOR WITH Japanese bearings .(one of the best motor out there for multicopter) the frame is almost identical to a Cinestar 8 and really well build an very strong 2mm carbon fiver plates. Each plate is 9 1/2 inches diameter and the boom are 500mm or 19 3/4 inches in length. with aluminum bracketsTHE OCOTOCOPTER IS NEW JUST BUILT AND READY TO FILM VERY WELL CALIBRATED AND WITH THE WOOKONG M GPS FLIGHT CONTROLLER, Real time telemetry TM1000, you can monitor your pack voltage and motor temperature live and also you can upgrade to altitude and speed sensor. IT HOVERS INCREDIBLY STABLE. THE CAMERA MOUNT IS From Helicam Solutions"STARTEC 8" customized for this aircraft A 360 3 AXIS VIEW WITH RETRACTABLE LANDING GEAR, EQUIPPED WITH AIR pneumatic RETRACS. IT COMES WITH THREE SERVOS AND THREE GYROS ALL YOU NEED IS A RECEIVER AND TRANSMITTER TO FLY IT WITH ONE CAMERA MAN AND A PILOT OR YOU CAN CONFIGURE IT YOURSELF TO FLY SOLO WITH AUTO GYRO CORRECTION.
Multicopter fully build
DJI Wookong GPS flight controller
Telemetry TM1000 pack voltage and teperature
8x Avroto(one of the best motor you can buy)
8x high amp May tech ESC(also one of the best you can buy)
Custom made powerboard from solid copper wire
4x batteries 5000mah
Spektrum DX8 transmitter-ar6000 receiver slightly used
10x 13.65 Carbon fiber props
Neck strap
Case for a Dx8 already used
Helicam Solution "startec 8" 360 camera mount(made in the USA) three servos three gyros bec and 2200mah battery with air retractsAll the components in this aircraft are among the best you can buy. The motors, ESC's, flight controller, props, camera gimbal, bec, batteries, etc...Please bid with confidence since i am an ebay member since 2003 with perfect feedback
email me if you have any questions.GREAT PRICE IF NOT THE BEST OUT THERE FOR A FULLY BUILT AND READY TO FLY LARGE SIZE MULTICOPTER.
SHIPPING TO THE LOWER 48 STATES ONLY.On Oct-21-12 at 12:19:51 PDT, seller added the following information: A lot of people have asked me about how much weight this Octo can lift. All I can say is that I tested this aircraft with a total weight of 10.5 for a full battery and the motors and ESC were barely hot. i would say about 102 Fahrenheit. at 60% throttle.
i am new here so i have this listed on ebay. http://www.ebay.com/itm/200838797187?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
Asking price is $4900
View attachment 7297 View attachment 7304 View attachment 7306 View attachment 7299 View attachment 7305 View attachment 7303 View attachment 7302 View attachment 7300 View attachment 7307
