Not sure what happened
Sforeal
So I built a 450 quad with a multiwii 2.5 with GPS and BT. Took it out to the field, messed around with the pid to get it fairly stable and started flying around. Everything was going great. Switched from acro to level mode flew around a bit. Now here's where it all went wrong and I'm not sure what happened... Went into a hover, switched back into acro. Waited a few seconds as the switch takes a few... The quad then went into a -76 degree pitch forward (I know this because the settings at time of impact were sadly etched in stone through the BT app) with nearly no throttle (throttle on the controller was about 50% and headed straight for the ground. Any ideas as to what happened? Needless to say I am now in the market for a new frame and another set of propellers.
F
fengshuidrone
Guest
They (multiwii FCs) take quite a bit of PID tuning sometimes to get them to fly properly. Your switch should work the moment you switch it, with no delay. With such a small amount of info on your quad it would be kind of hard to diagnose exactly what happened. With nothing more to give but a guess on my part, my first question would be did your props come loose? Sounds almost like one or two of them started to free spin, or maybe one failed completely. Are you using quality props? Also, when you switch from level mode into acro mode, the craft will no longer return to a level state on its own. Whatever direction you point it in it will keep going. In acro the craft must be controlled at all times both in pitch/roll as well as throttle. If you are pitched forward when the switch is flipped it will keep going forward and with no throttle correction it will go into the ground. Also, there is a process to center up your TX so the FC flies things right. If you skipped that you will have nothing but problems until you do.
