Mikerodrig27
Hey guys. I'm building a Quadcopter for taking video (GoPro 3+ Black) on the big island of Hawaii where my wife and I will be living. I'm looking to build over buying a RTF or ARTF because I want the experience behind building and tuning it myself. My goal is to have a unit that is very stable for smooth video, and to have enough battery reserve for at least 20 minutes. Not planning on doing flips ect. Here are some of the parts that I've figured out so far. The top end of my budget is $850 with charger and telemetry. There's a lot of questions so if you only want to help out with part of the list, all help opinions are welcome. Thanks!
1) $54.49 280g Frame: Ordering two to make repairs of modifications.
2x https://www.hobbyking.com/hobbyking/store/__22781__Turnigy_Talon_Quadcopter_V2_0_Carbon_Fiber_Frame_550mm.html
2) 4x motors: I've heard good things about SunnySky motors. I don't mind paying extra for quality and efficiency if it's worth the money. I've used two calculators that say that I need 4.1s batteries with 756kv motors or 657kv w/ 3S?... I'm sure I did something wrong. The weight (according to my calc) is going to be 1.97kg loaded with a 3s 5000mah battery, gimbal, and gopro. Does this seem to heavy? Also, are 22 pole pancake style motors are more efficient? Would I be able to use them? I also want to be able to run two batts in parallel for longer run times.
3) $3.99 27.3g Distribution Board:
4) 4x ESC: Still planning this. Any suggested brands of ESCs that are proven?
5) Transmitter: Have heard good things about it and it already comes with the receiver which is nice. There's also a lot of support and mods for it.
https://www.hobbyking.com/hobbyking..._Module_8ch_Receiver_Mode_2_v2_Firmware_.html
6) Male to Male servo leads: Just need the proper length I assume.
7) $279.00 54.8g Flight controller: I can't figure out any reason not to go with this FC. Thanks Earp.
3DR Pixhawk w/ uBlox GPS and Compass Kit
8) Propellers: Going to get two sets of Carbon fibers and two cheapy sets. From what I understand, smaller props make a more stable copter where as larger props make the copter more efficient. One calc says a 550mm wheelbase + quad can handle 15.31" props so I think i did something wrong here... Here's what I've seen other Turnigy Talon 550mm users use.
10" 4.5-5 pitch
9" 4.5-5 pitch
9) Batteries: I want to know if setting up the quad to carry two batteries would give me longer flight times.
5000mah 3s or 4s.
2x 5000mah 3s or 4s in parallel.
turnigy nano tech?
10) Battery charger:
Whats a good charger for a wall socket?
11) $124 200g Gimbal w/ gyroscope:
Tarot Brushless Gimbal for Gopro Hero 3 TL68A08
http://www.rcgroups.com/forums/showthread.php?t=1917049
12) Servo Leads: 10 x 10cm 3 pin male to male
http://www.hobbyking.com/hobbyking/...e_to_Male_Servo_Lead_JR_26AWG_10pcs_set_.html
13) Lipo Sacks for charging
10" 4.5-5 pitch
9" 4.5-5 pitch
5000mah 3s or 4s.
turnigy nano tech?
