eyeinthesky
I recently started Flying my DJI S800 it sat on the shelf for a while i have flown it in stock condition with the IMU mounted in the stock location on the center flown lots or times no issues. So my question is
#1 Should i buy the high frequency vibration isolator kit and mount the imu on the plate insted of where it is now . for safety ? does it really improve flight performance and does it save you from flip of death ?
#2 what is the voltage comming out from the gimble wires on the main hub ? if im using a 6S battery for the flight battery will the voltage be the same as that ? i want to attach the Tarot Gopro gimble and it neeeds 3S /14 volts what is the best way to supply that power ?
