I am building my first quad and am trying to mentally button up all questions before I start the actual assembly. One of my last purchases is the TX/RX setup. I am leaning toward the Turnigy 9x and 9x8c combo. I have the Acro Naze32 running Cleanflight and would like to use the programmable LED function. As far as I can tell the 9X setup will only allow me to use PWM. PWM will have me connecting signal leads to each channel(1-4) on the Naze. I have also read that the Naze uses Ch5 for the LED output. I assumed this would be ok and I could use Ch5 for LED since I only connected up to ch4. But now I am reading that I have to use PPM, meaning I only hook up 1 signal wire to Ch1 on the Naze. Then when I select PPM as my RX type on the Cleanflight GUI I will be able to use Ch5 as my LED signal output.
Am I reading all this right? Or am I able to use the programmable LED function while still using the 9X8c and connecting to ch1-4?
