The fast oscillation is either the gain is too high or the props are the wrong size for the motor/battery ccombo you're using. The easiest thing is reduce the basic gains about 10% and see what happens. The way I usually test is set both basic pitch and roll to be adjustable from the TX assuming you have an available slide or knob to do that. Set basic P & R gain to 100% at the midpoint of the adjustment range and then go fly it. Starting at 100% get into a hover out of ground effect, 10 feet should be good, then punch the throttle straight up for a second or so. If it doesn't oscillate as it starts climbing, slowly increase the gain settings until you see it start to oscillate as it climbs out then back them down to the point where it can climb hard but smoothly, that will be the optimum gain settings for basic pitch and roll.
If you find you're having difficulty getting the gains locked in no matter the settings then it may be the props, try the next smaller size, i.e. go from 10 x 4.7 to 9 x 4.7 and repeat the process.
HTH
