NAZA problem...help needed
cappy2449
trying to troubleshoot my problem and am getting no where...dji f450 w/naza and gps...everything dji stock...tried to plug in my 3s lipo got a small spark...now the naza doesn't go thru its sequence..no sound and the motors won't arm...also led light strips on arms don't light up(soldered on)..rx ar8000 is bound and led is lit..i am getting a flashing green light in gps mode,yellow in atti and no light in manual..everything in software assistant looks correct..tried reloading firmware and still the same problem.....did something possibly short out?? can i rule out the naza unit? maybe i should try putting on a new battery connector...help is appreciated....PLEASE...Prior to this everything was great..very stable..RTH worked flawlessly..gps mode was rock solid ....no crashes....
DesJardins
I would complete the firmware process, re-write everything into the Naza, calibrate everything to start.
Anyone local have a Naza to try out?
Are your motors beeping during the initial plug in?
Is the LED working on the BEC indicating the different modes. Yellow for Alt, Green for GPS of you have a compass installed?
cappy2449
ok..thats what i thought you meant...i already did all of that..still the same results...no one local to test out naza unit....i am thinking something shorted out?? maybe try a new lipo connector to the board...or maybe vu went bad?? no way to test ?
cappy2449
caps look fine...just tried to see if i could go into calibration mode and i could...worked fine...bec is flashing correctly in each mode...got gps lock...but still no beeps on initial plug in
DesJardins
Ok so everything registers in assistant with stick movement, switch selection works, LED is working but your just not hearing the audible initialize?
DesJardins
Try turnin off your "voltage monitoring" in assistant and / or recalibrating the voltage...
Rebound the Tx and Rx already correct?
mailman35
if u arent getting sounds then the esc's and motors dont sound like they are getting power, as the sounds come from the motors.
everything soldered correctly?
cappy2449
it was working for a few months...i just noticed a small tear on the negative wire of the bullet battery connector...is it possible to short these connectors out?...that might explain why i got a small spark when connecting to my lipo??
DesJardins
Well it seems you have tried the majority.
I say replace the plug and cross your fingers!
Or you might need to put on a new bottom board to rule that out too
cappy2449
hey thank you so much for taking the time to help...i appreciate it...going to change the connector and i will let you know of the outcome
cappy2449
so i found the problem but am a bit confused...i have led strip lights soldered to the esc connections on the board...so i decided to connect the led strip lights to the balance connector of the lipo(led lights are still soldered on)...when i did this the led strip lights lit up and the f450 powered on and was able to arm the motors...pull out the balance plug and the motors shut off...glad i found out the problem but have no idea why this is happening or what to do about it...
rodgzin
wow man, this is really wierd! still no idea? still same problems?
cappy2449
thru process of elimination i am going on the hunch that it has to be the VU....ordered a new one...will let you know...
cappy2449
so i received a new VU..soldered it on ...and sorry to say still the same problem...connect end of led strip light to balance connector of lipo and i get the initial plug in sound and motors arm..unplug it and motors shut down....anyone have a clue what could be going on?? this is making me friggin nuts!!
