Naza-M V2 with H3 2D Gimbal
SkyBoss
Hi,
I need to know if one can connect the GoPro H3 2D Gimbal, with Naza-M V2, using two seperate receivers... one for controls of the Multi-copter and one for Gimbal control.
The setup which i have in mind is:
1. F550 with H32D gimbal and GoPro.
2. 5.8 Ghz AV downlink
3. Ground end:
1. One Tx for Multi-copter control
2. 2nd Tx for Gimbal control
rilot
No because the GCU only has a CAN bus input. But why would you want to? You can only control the tilt angle with the H3-2D so your second tx would have 1 control on it.
SkyBoss
Thanks for the reply..... yes, would be better if one Tx handles both functions...
rilot
I thought about this some more and I'd like the change my answer to "yes". There's nothing to stop you hooking up a second receiver to the X1 port of the Naza (gimbal tilt) but it's a lot of complexity just to operate the tilt.
