Naza low voltage protection settings
hazardpro
Hi all, need some help with my low voltage protection settings on my Naza's
If I'm honest I don't really understand what I need to enter etc or how to work it out.
I have two setups:
TBS with 4s 4000mAh (safely flying for 10mins) - battering reads approx 3.8 per cell after flight.
I turned on the V warning in assistant using the following settings:
1st level:
no load 15.4 - 0.5v loss =14.9v
2nd level
no load 14.8v - 0.5v = 14.3
After only 2-3 minutes I was getting red flashing light on Naza when under load.
My second set up is new. Running 3s 3350mAh
Using assistants default settings I was getting red flashing light after only 2mins....
If anyone uses the same batteries and can share their settings or if anyone can recommend it would be appreciated.
PS Does / would the Naza display a red flashing light under load for any other reason/fault?
Doug
