naza lite LED help
dbeck0503
When I am flying, in gps or attitude mode I get a double flash.... 2 green flashes in gps mode once the quad is in the air, or 2 orange in attitude. That is with full satillites. It will have one flash when it is on the ground, then when in the air it changes to 2. Is this normal? I thought it should always be one flash, then the amount of satillites with the red?
cootertwo
You'll get a quick double flash, anytime any stick is past center. NORMAL Naza thing. Lets you know when everything is centered, as it should be when everything is calibrated, and setup for half throttle hover etc. etc.
dbeck0503
Cool thanks! I must not have noticed it before. One more question. I moved the gps towards the front. Closer to the gopro, and it seemed like it took a longer time to connect to the satellites also I don't think it fully connected I still had one red flash. Could it be the gopro interfering? It was around 25 degrees F out and overcast. Maybe not connecting due to weather?
