naza lite failsafe
fsalyers
I am setting up my 450 quad and if i manually turn on a switch to failsafe does it override the controls, if I check failsafe by turning off my transmitter it goes to manual mode, does anyone know why, dx7 trans.in heli mode have using the flight mode switch manual, attit, failsafe, I don't have gps, need dx7 setups
Thanks Fran,
Benjamin Kenobi
Easy? You call that easy?
Yes, failsafe overrides the other controls. Flick the switch between atti and gps a couple of times to get out of failsafe (in flight).
You need to rebind the receiver to the transmitter in failsafe mode. Turn everything off and switch on your failsafe switch on the transmitter. Put the receiver into bind mode (bind plug thing) then switch on the transmitter with throttle at 50% whilst pressing the bind button. Receiver light goes solid. Turn everything off. Now your failsafe should be set. Test whilst connected to the assistant.
Cool? :tennis:
