I hung on for quite a while after seeing the latest 2.0 firmware release. So with a degree of trepidation I gave it a try today. It has the compass checker like the new Naza-M which was great. All in All I have to say well done to DJI as this product is in MHO great value for money and works really well.
The instruction guide could be improved as the way in which tail gyro gain is adjusted is not clear at all or even mentioned. For those interested you need to assign the G channel to a two position switch and by trial and error set a high and a low value in your tx. Mine is set at H= 42% L=38% Quite low values are required!
If you are using Spektrum then heli mode will by default set your gyro on the Flap/Gyro channel which is a three position switch. Be careful here because if you select the mid position in flight you will have an interesting time with 0 gain.
It was quite windy today yet in manual mode it was hovering hands off at all compass points. I was about to try a 5 rotor head system but with this superb level of stability I wont bother. As with naza-M the new algorithm is excellent.
Also FWIW DJI Europe is fully functioning now and you can get your stuff serviced at last.
