Naza GPS magnetic declination adjust - does this affect course hold mode?
Totality
I was suffering the toilet bowl effect so was advised to turn the GPS 20 degrees to the right. The quad now holds OK in GPS mode. This, however, seems to have broken course hold mode! The manual states that course mode is set after power on, but if the GPS has been turned so that the arrow points 20 degrees to the right, does this mean that the "course" is now 20 degrees away from the front of the craft? IE If you push forward the quad will not go straight but at whatever direction you set the arrow at?
That is what I am seeing but just need to find out if the theory is correct or not to try and fix it. If I set course hold mode and press forward, the quad does not go straight ahead, but appears to follow the direction the arrow points on the GPS? Is that correct and if so how can you fix the GPS toilet bowl effect and have course hold working too?
