A 5.8 Ghz will give you more bandwidth but vastly less range than lower frequencies such as 2.4Ghz, 900 Mhz, 433Mhz. If your RC systems is 2.4Ghz, best not to use that also for video downlinking. I prefer 433Mhz because it is longer range and restricted to use by HAM radio operators which I am as well. (less radio use in these areas). Any cable can pick up radio frequency interference. Longer cables and those of the specific lengths to match the radio signal will be even worse for radio frequency interference. It's all about the radio signal wavelength relative to the cable length but also fractions and multiples of the wavelength which allows in harmonics of the radio signal. Another strategy to discourage RFI is to make cable sets with twisted pairs and/or to coil your longer cables. Don't try to do the math without taking a HAM radio course however.... just experiment with changing lengths, coiling and twisting the cables. Shielding cables is a last resort but technically requires one or both shield ends to be grounded to earth..... hard to do when the device is in the air!!!
