Would it be better to run the servos for a camera Gimble on 6 volts thru a regulator and just the signal lead to the Naza or just go ahead and plug the servos directly in to the Naza. I have a small gopro Gimble I am going to use that uses the miniature Hitec 55 servos.
I gave up running my servo's thru my WKM and went to a CC BEC. Digital servo's are power hungry beasts. If something happens to a servo it can affect your fc. Since converting I got to say the WKM and the gimbal seem happier, not to mention my piece of mind.
In the manual for the Naza it recommends using a separate BEC for gimbal servo's, I have always done so and have never had a problem, it is very easy to make up a power lead using a couple of servo extension leads.
