Hi laitys, if you are using Naza flight controller check your voltage monitor settings in DJI Naza Assistant (the software settings assistant). First level and second level protection must be set correctly if the Protection switch is ON. Also calibrate the voltage if required (check with a good quality multi meter). Set the correct battery type 3S, or 4S (this is very important).
The hexa otherwise looks good.
Regards - bruce
