My (first) quad build part list - can you take a look and check I didn't mess up ?
HoloPed
I've flown some small quad and helli toys, I now want to build a quad that can carry a camera.
The goal is stable, controlled flight for photography. No tricks or aerobatics.
Here is the part list I have compiled:
Naza M-Lite+GPS - http://r.ebay.com/ZiledI
F450 Frame - http://r.ebay.com/FHHyrw
4in1 ESC EMAX 25A - http://r.ebay.com/kuhjPd
SUNNYSKY V2216-12 800KV - http://r.ebay.com/iZkBIH
APC 10x4.7 Props
4000MAH 3S 25C Battery - http://r.ebay.com/etmZJx
Cheap LIPO charger - http://r.ebay.com/9FimXf
Turnigy 9X 9Ch Radio
Does this make sense?
Am I missing something?
Thanks !
PeteDee
Mr take no prisoners!
Thos frames are okay but choose one that has the built in PCB for power distribution.
Look for SunnySky 2212 900kv motors and use 9x5 CF props, bit better on the stability and a little lighter.
Just go 4S from the start, 3S is not where it is at if you want to carry a load.
Save a bit more and get a better radio, at least a Taranis.
Cheers
Pete
jbrumberg
Make sure that the transmitter comes with a receiver and you will need 3 pin servo wires to connect the receiver to the flight control board. I believe that you will need CW and CCW props as well. One gets what they pay for with battery chargers. That unit looks cheap. I would recommend getting a multimeter as well.
Good luck.
Jay
HoloPed
Cheers
Pete
Would I need to solder into the frame ?
Why is this better than cables ?
I need a 4S 14.8v battery ? I noticed that 3S are 11.1v.
Can you explain some of the major benefits of a better radio ?
Thanks !
You don't need to solder into the frame; a frame which allows you to would be a big help, as its a lot neater and cleaner, but it isn't necessary. You could just use a distribution board or harness.
It's lighter than cables are, and looks better.
Using a 4s battery is more efficient, more powerful (for lifting capability), and wlll fly longer, usually.
Better radio is just better. You'll get better range, reception, the quality is better so you won't worry about it breaking or anything.
Mojave
APC 10x4.7 Props
Thanks !
HoloPed have you red through this posting?
http://www.multirotorforums.com/showthread.php?14280-Group-Build-DJI-NAZA-F450-Quadcopter!
This is what I used to help me build my F550. This is a valuable syllabus to get started. I bought an actual DJI frame, there are a lot of 'knock-offs' from companies imitating DJIs Flame Wheel frame. And I agree 4S batteries are a good way to go. Here is another posting to read about Lithium polymer batteries:
http://www.multirotorforums.com/showthread.php?12819-Understanding-Lithium-Polymer-batteries
