On another forum a newcomer was asking for advice on where to start with multirotors. A regular poster there suggested he buy inexpensive HK parts to build a quad using their F450-lookalike frame as a way to get his feet wet. This got me to thinking that it might be a great adventure to buy a set of parts with the intention of using them as a sort of multirotor construction set. With enough basic parts to put together a variety of MR configurations plus some spares I could experiment and see what I like and what works for me. I would stay with inexpensive parts that may not provide great performance, but should suffice for experimentation.
This thread is me asking if that seems a good idea, and if so, whether the parts I list are appropriate.
So first, any comments on the general idea? Am I being silly? I am a hands-on type. I enjoy kits rather than RTF/BND, etc, so being able to switch things up sounds like fun to me. I imagine it would be a great learning experience.
As for the components I have in mind:
1. A hexa frame: 1 x H550 V2 Glass Fiber Hexcopter Frame 550mm - Integrated PCB Version: $26.99
Since I am drawn to the hexa I start here. For other configurations I can either build my own hubs from fiberglass or Lexan and re-use the arms, or build entirely from scratch.
2. A quad frame - 1 x Q450 Glass Fiber Quadcopter Frame 450mm - Integrated PCB Version: $17.99
This gives me 4 spare arms for cheaper than I can find elsewhere, plus I have a nice quad hub too.
3. A flight controller - 1 x Hobbyking KK2.0 Multi-rotor LCD Flight Control Board: $29.99
It's not the Naza with GPS I was planning to get, but it is inexpensive and it supports every configuration with 2-8 rotors I have ever heard of, plus some.
4. Motors - 10 x Turnigy D2830-11 1000kv Brushless Motor: $9.56 ea
This gives me enough motors to build an octo, with a couple spares. I know that no one motor is ideal for every situation, but I'm hoping these will be sufficient for most. Am I right?
5. ESCs - 10 x Turnigy Plush 30amp Speed Controller: $12.19 ea
This is an ESC for each motor. The parts list I started with suggested a HobbyKing Red Brick 20A ESC, but the motors above state 30A ESC. A lot of posters seem to be using this ESC. Is it a good choice?
6. Props - 2 x Slow Fly Electric Prop 1045SF (4 pc): $3.07/pack 4; 2 x Slow Fly Electric Prop 1045R SF RH Rotation (4 pc): $3.07/pack 4
OK, these are no Graupners, I know. Will they be sufficient? At this price I can break a few. I also think I might want to get similar numbers of props at 9" and 8" as well. I would also like to get some three-blade props to try, but I'm unsure about size.
7. Receiver - 1 x OrangeRx R610 Spektrum DSM2 6Ch 2.4Ghz Receiver (w/ Sat Port): $5.99
I am planning to purchase a nice Futaba in the future, but for now I have a Spekky DX6i that should be sufficient for the KK's needs. This is a super-cheap RX. Is it usable?
8. Receiver leads - 1 x 10CM Male to Male Servo Lead (JR) 26AWG (10pcs/set): $4.75
That should be enough, right?
9. Batteries - 2 x ZIPPY Flightmax 2200mAh 3S1P 30C : $17.17 ea; 1 x ZIPPY Flightmax 4000mAh 4S1P 40C: $35.10
That lets me do 1x3S, 2x3S, or 1x4S.
10. Connectors - 5 x PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC): $1.59/pack 10 pair
That's 4 per motor/ESC, plus some spares. Are these going to work?
11. Wire - 3 x Turnigy Pure-Silicone Wire 14AWG (1mtr) RED: $1.39/m; 3 x Turnigy Pure-Silicone Wire 14AWG (1mtr) BLACK: $1.39/m
That's about 10' of each color.
12. Miscellaneous: Soldering iron, solder, flux, shrink wrap, zip ties, battery connectors, battery strap, thread lock, CA, servo tape.
Well?
I appreciate any constructive comments. Thanks.
- Tim
Well?
- Tim
