Howdy gang,
Does anyone have any experience in multiplexing low-res video feeds?
The idea for our system is that we have 2 low res outputs from the multicopter (1 on the chassis to assist with flight, and 1 directed with the camera to coordinate photography). Working on a 5.8GHz transmitter, ideally we would like to get both feeds through the same stream.
One idea is to multiplex the signal into altering frames, and processing on the ground station.
Another is too take advantage of a rgb signal, and send different signals down each color, and use black and white output.
Regardless, I thought it might be an idea to see if anyone has tackled this challenge before we have a crack.
For reference, the basic setup we are looking to modify is-
http://www.readymaderc.com/store/in...ducts_id=433&zenid=vfn1t1vb7df7gnkp913tg5va42
(with a go-pro low-res output as the second feed)
Cheers
-Dan
Cheers
-Dan
