Some majors broadcasters accept only interlaced programs or PSF them prior to broadcast. All news are interlaced, as well as dramas and sitcoms. they are full HD not SD...
Blu-ray is interlaced as well, not progressive.
Actually this is your final output that decides the settings.
You don't shoot interlaced for Youtube or Vimeo, and you don't shoot progressive for TV news.
Prefer Manual Exposure.
Prefer Manual focus if possible. Know your DOF. (depends on focal lenght, sensor, and aperture...)
Shutter at 180 degrees for normal conditions, which is roughly double of your shooting fps. But you can create effects and change the exposure by playing with it. (film a fan and change the shutter speed to check...)
ISO as low as possible
Target the sweet aperture for your lens (Usually about 3 F stops from the max aperture) so if you have an F/2.0 try to shoot at 8
Do not shoot at F/22 or more, your iris is so closed and so small that you loose the best of your lens capabilities. Instead use a ND filter (0.9) put you back 3 stops Back to F/8 which is much better for your picture quality.
Prefer to be slightly under exposed than overexposed. You can't bring back what was burnt in post.
Film Flat: Not too sharp, not too contrasted, not too saturated. You will have more room to play in post.
It's already a lot to think about...
