Mounting Dual Receivers
AirPix
I'm using JR AR8000 receivers with a main Rx and a satellite Rx. I'm trying to figure out the (a?) optimum location for mounting the second Rx. The main Rx will be mounted on the main board next to the Naza FC, with the single antenna wire pointing forward.
The two multicopters being built: a Gaui 500x and a Gaui 300sx.
On the 500x, my first idea for the location of the secondary Rx is on the left side of the central frame with the two antenna wires oriented vertically, perpendicular to and within 2" of the main antenna. This would get it somewhat remote from the main RX and oriented correctly. Another option would be to make a bracket to fit on one of the aluminum motor booms and place it a bit further out from the main Rx. I'm not sure abut getting it close to a metal boom, though, and the aluminum boom has am ESC and motor power wires in it. Since the booms on this multi are foldable for transport, there are limited options for mounting on the booms.
On the 300sx, I can see mounting it on one of the glass fiber composite motor arms, and place the ESC "a couple of inches" from the secondary RX, and also carefully route the power wires to be "not near" the Rx. Another option would be to place the Rx in front, 3-4" ahead of the center frame on an it's own small boom.
With either multi, mounting the secondary Rx in the rear is not a option-- the Naza BEC "VU" has to be mounted in the rear and I want to separate the Rx fro it.
One idea: the folding GOS antenna mounts that I ordered arrived today. I wonder if I could not make a mounting plate for the secondary Rx and attach it to the GPS antenna boom. The is plenty of room, and since receivers tend to be passive devices, the two Rx's shouldn't interfere.
--Bill
FlyGirl
--Bill
One of the things I was always told when mounting a satellite Rx is to make sure that the satellite was mounted perpendicular to the main Rx. For instance, if the main Rx lies flat on a surface then the satellite should be placed like you would place a picture on a wall which results in a 90 degree variance. Just to make it clearer here is a picture of what I mean. You can see the ar8000 is lying flat while the satellite is mounted out on the arm at a 90 degree angle.
AirPix
Sure, perpendicular is the recommended orientation for the remote RX antenna. But what restrictions are there about mounting the receiver near metal rotor booms? Or close to motor power and ESC wires? Minimum separations from these items?
--Bill
