Motors don't run at the same speed.
Fixy
Hi, trying to get my NX500 in the air. It has a multi Wii controller and 4 E flight motors and esc's. When throttling up only 3 motors try to lift. The 4th does not turn. If I apply full aileron or elevator to the side with the motor that is not turning the motor then turns and tries to lift just fine but it is not fly able. Is there a setting on the Multi Wii to correct this? Thanks James
Fixy
No, not sure how. I also thought thats probably not the issue as it does run at different stick settings. I will read up on that and try. Thank you
Fixy
Ok, getting more frustrated. Went to calibrate the esc's. The previous owner has cut the plugs off and extended the wires and one has 3 wires, the rest have two wires. I know this is the proper set up but sure makes it difficult to calibrate the esc's. I also am not able to identify the esc's. No labels only microscopic writing on them. The first two letters look like an HW so I'm guessing Hobby wing but can find no more info will keep looking. I have a multi wii SE board and spent 2 hours online trying to find basic set up. Pretty confusing board b I will keep trying, if worse comes to worse I will put one of my KK2 boards in. An the really good news is I have managed to change some setting and the motors won't arm now. Glad I have two other quads to fly.
Fixy
I gave up on the multi wii, put in a kk2 board and everything set up first try. Even got my dx8 to bind. Flies not bad but needs some tweaking.
