I am starting to get parts for a 250 racer. I have noticed that some motors say CCW or CW. Then there are some that don't say CW or CCW. Do I need to pay attention to the rotation of the motor or is it in the props?
If brushless motor it has 3 leads and if motor running wrong direction reverse any 2 of them unless the ESC allows for changing direction like on Vector and others. Rotation direction is per the controller and yes pairs diagonal from each other. Do cw and ccw motors come wired to ESC? Only logical way to fix direction I know of.
I was thinking the same way as Brent. Now if your props have nuts like my F450 then you have to have CW and CCW motors. I have seen people use nylock nuts and wondered if they were standard direction threads. I should have asked. As of now I plan to use 4 identical motors with nylock nuts. Am I correct thinking this?
CW and CCW is probably referring to the prop hub so your props dont unscrew during flight. It's becoming more common on the little 250s to have this option.
That means one has to make sure motors put in proper position for marked rotation and rotate that way. So far on 3 quads I just use lock nuts, no issues and simple.
