Hi,
I am interested to buy this motors for my x8 build but this the only thing i can find regarding them. I am planing to use them with mytech esc 40A opto simon K
Anyone have same table with A current thrust and different size of props?
Pls share anything regarding them especially if u are running them on 4s
Description
This is a 14pol Brushless Outrunner High Torque for Direct Drive
This (specially designed for the MikroKopter) black anodized engine has extra-long cables, short shaft (ideal for coaxial arrangement).
The motor is balanced with mounted propeller adapter!
Propeller recommendation:
• 6S-Lipo (25V): 12", 13" or 14"
• 4S-Lipo (16V): 16"
• CFK-Propellers
Technical Data:
• Lithium cell count: 4-6 (16-25V)
• Load current: max. 25A
• Maximum load current. 30A (30 sec) and 40A Burst (5sek) A
• No-load speed: 490 rpm/V
• Mechanical power: 380W
• Thrust max.: 3000 g
• Wire length: about 52 cm
• Total weight (without cable): approx 111g
• Dimensions: d=36mm, h=44mm (incl prop adapter: h=65mm)
Delivery Scope:
• 1 Motor
Accessories: propeller mount 5mm and mounting material.
Sent from my iPad using Tapatalk
Description
• CFK-Propellers
Technical Data:
Delivery Scope:
• 1 Motor
