jetforce
FLY HIGH AND STAY HIGH
Hi I`m going to put MK with Aerodrive 8 on my new SkyJib 8, so reading a lot on the german MK forum about Atti and PH not working so well.
I got an idea.
Everybody has the same problems with MK systems, the 8mm or 15mm rubber-dampers
takes all the high frequence vibration from the motors and props. But they
are too soft so that the hole board can move too much. That meens that the
Copter is not holding Atti and PH as well as we want it to.
MATERIALS NEEDED:
Two of those : cap for GPS-Cover 64 https://www.mikrocontroller.com/index.php?main_page=product_info&cPath=65&products_id=410
8 x : Bolts M3x8 https://www.mikrocontroller.com/index.php?main_page=product_info&cPath=77&products_id=280
8 x : Screw M3x8 black ( it has to be with a Y head so it can be sunked into the board/cap.)
1 square of gyrotape or better Alpha-gel 3mm.
First attach 4 bolts and screews to each board/Cap.
Then glue the two plates together with gyro-tape or alpha-gel 3mm, with 4
bolts pointing up and 4 down for attaching to the frame (bolts down)and MK
tower (bolts up)
This will isolate the vibrations like we nomaly do on RC Heli-Gyros, and
make the hole MK tower stable, so no wobbling.
I would like to hear your opionion on that.
I got an idea.
MATERIALS NEEDED:
tower (bolts up)
