mixing switches for fail safe
paktazh
I got a problem with mixing just want to make sure that I do not make any mistake first I got WKM with GPS
so in order to mix the second switch with 3 way switch since 3way switch can go to GPS A M but not on the froth one so if i mix the second switch with 3 way switch in order to turn the fail safe Blle in DJI software does the 3 way switch has to be on blue as will as the second switch that set for fail safe in the same time . If some thing happens the GPS bring it home back while it is on fail safe mode too or the GP A an M they do not have to be on blue and only the second switch that set for fail safe has to be in fail safe mode and blue in WKM software
