did you guys update the bootloader before reinstalling the firmware? I had to do that to get GCS to show all the screens. I can reference the thread from OP Forum in the morning if you want to give it a try.
Bart
I did a clean slate, erased the settings in the board, updated the bootloader, then reloaded the firmware, same problem with GCS.
I found a workaround for the update rate settings and now have the quad flying very close to as smooth as the other one with the Hoverfly Sport board on it, only remaining issue is the level is off a tiny bit so if I use attitude mode it drifts forward and to right a little and without access to the calibration in GCS I can't fix it. Not a major issue as I don't really use autoleveling on the small quads, mainly I beat the snot out of them doing aerobatics in a big open field and so far this one looks like its going to be a good one for that!
Eventually the problem will get fixed one way or another, its more of an aggravation that I can't get the GCS to run at all on the netbook I take to the field for running MKtool on the MK hexas, so I have to do all my tuning here at the house and hope that the settings I wind up with work well when I have the room to open it up and bang the sticks around.
Update - I got GCS to run on the netbook, the problem was the antivirus software thought the GCS executable was a threat so it removed and quarantined it! Haven't yet had a chance to hook the board up to it to see if I can access calibration...
Update #2 - hooked the board up to the netbook and did a reload of the bootloader and firmware, got the calibration screen in GCS. Moved the board over to the desktop computer, now have calibration screen there too, problem fixed!
