Mikrokopter Mikrokopter FC 2.1 no signal from the receiver :(
Pablo74
Hello everyone, I have a problem with a OKTO 2.1 fc
After some tests at the counter while my length absorptions and temperatures
suddenly came off the power cord from the DB.
When the power back OKTO out the error signal loss
receiver with futaba quadroppm, replace the receiver thinking it was the quadroppm with a Jeti but the error is no signal coming out fromto receiver, if I connect via mktool mkusb and turn on the radio telemetry, but if I unplug the ribbon cable from FC beep beep
same thing.
In section obviously does not see the radio channels ...
What I do not know what to watch ..
I ask your help, thanks
.View attachment 4379
I don't use Jeti but do you need to bind the satellites to the radio? are the channels assigned to the different POTI's in the channels pages of MKtool?
are there any other error messages when you first connect to MKtool?
Pablo74
Hi Thanks for giving me reply,
In MKtool not see any channel, unfortunately, this is the second recipient feel that the FC work I tried the gyro and acc and work, I tried again to load the firmware but nothing, which I think it jumped the track of this ppm point and I'll see if I can pick up the signal from another part,
looking at the pattern http://mikrocontroller.com/files/Flight-Ctrl_ME_2_1f.pdf
the only available place on atmega cpu :( I see quite a challenge.
have any ideas?
Thank you.
G.
have any ideas?
wizprod
have any ideas?
Thank you.
G.
have any ideas?
Try again with the jeti. Have you selected the right reciever-type in mk tools?
G,
Photos would be very helpful. If you could take a picture of the underside of your flight control we can see if the wires are connected correctly. checking to make sure that the right receiver type is selected is important, as wizprod said. the receiver type can be selected on the channels tab of mktool.
Pablo74
hi thanks all, yes all correctly select in mktool and jeti bridge, the problem not current because i measure with tester amd all ok for voltage, but the ppm signal i think have a problem, i change two rx and not found.
in the nex day I send the fc to germany for assistence :(
