Middle of the road Multi
suicidemachine
I don't want a toy, but i don't need top of the line.
My guide line:
I have DX6i ,
able to mount go-pro ,
budget:$150-$300ish.
just need some good web stores or models to check out.
thnx James
I would look at HobbyKing and check out their quad frame kits, see what motors people post there using that frame, as well as the HobbyKig flight controller. You could go with DJI F450 and Naza-lite, but I think that will run you closer to $400.
to have any chance at an easy line to success, i'd get a naza lite and whatever frame fits your budget. the f550 is pretty cheap. a decent set of motors helps alot though and there not in a dji arf kit. sunnysky 2216 900 kv would be better, dji 30 amp opto are turn key and work well
+1. I wanted to add above that "middle of the road" can't be done with the budget you mentioned. If you truly want middle of the road, do as Kloner says and up your budget to $500 for a starter kit that you can grow and expand over time as more budget allows.
