My MC is located at center CG so my position data for the MC is 0,0,0. My GPS is mounted on the supplied pole and attached to the forward right screw set used to mount the top plate. I measure the positon to be -9, 8, 0 cm from the MC. The Naza Assistant asks for the distances in centimeters (cm) but many I've talked to using this mounting position enter the numbers as mm (-90, 80, 0). Does the Naza Assistant want the distances in centimeters or millimeters?
