I've ordered an F550 from AMP (easy to order online, nearly impossible to get a principle to talk to or respond to e-mail ). A couple of questions:
1) Does it come with the wires? The Manual implies that it does not.
2) I'm going to add FPV gear after the build or maybe during if it all gets here in time - IRC 600mW vtx, mini iOSD. The GoPro will be the FPV camera. Is there anything I should do during the build process that will make adding that gear easier?
3) If I want to run two lipos on this F550, is there anything I should do during the build process to accommodate that?
4) What is the name of that wire mesh that folks use? Similar function to heat shrink tubing.
5) What kind of solder does one use?
