I managed ok with ver 1.2 but now since I upgraded to V1.6 I can't calibrate either! normally you turn on your transmitter & set throttle to maximum, now hold down buttons 1 & 4 on the KK2 board, keep them pressed all the time & connect the lipo, you will hear all the ESC's go through their startup cycle (make sure props are OFF), after the ESC's have set high range & all the singing & dancing has finished to move your transmitter throttle back to minimum & let the ESC's sing & dance some more...when they have finished you release the buttons on the KK2 board & power off...that's it!I received my new board and have been slowly reassembling my f330. However, I no longer see the esc calibration screen? How do you calibrate the esc's now?
Dooo,,,, thanks Ross, don't know how many times I read that. Good thing I'm getting long in the tooth, can't remember anything half the time and the other half I forget!
Thank you so much, that got my servo to working and now I am trying to test fly it and it yaws the correct way, left is left and right is right but when I lift off , it won'ts to turn clockwise circles? Can you help with that anyone. Thanks so much for your help.
