So I just finished up assembling my XA hexa frame with DJI WKM, and the motors and esc's recommended by Jeff at CNCHELI. They are the same as in his XA HEXA package - AKE Quad Dancer motors and AKE 12amp escs). I have the XA gopro camera gimbal, and am using a new Spektrum DX8 and AR8000 rx.
After spending the last couple days working through the DJI instructions and configuring the system through Wookong Assistant. I programmed all the ESC's according to the AKE directions - brake off, cutoff mode set to cut-off, start mode to normal. I left timing set at default, as I could find no info on appropriate settings. I clipped the red wire power wire from the ESC to the MC, and in the various flight modes (atti, GPS, normal) the status LED seems to be indicating normal.
I successfully performed the compass calibration, and when I attempt to test fly, I get no response from the motors at all. When I first power up the system, I get a slight twitching from the motors for a second, but aside from that, i am not able to get any output from the motors at all.
My suspicion is my problem lies with the ESC's programming. I attempted to test this by powering a seperate Spektrum RX I have with a batterypack through the batt port and connecting one of the ESC signal leads to the the throttle output of the second RX. I am getting no response from the motor, but I still am unsure about this....
Anyone have any suggestions or ideas?
