is there a bug in in firmware 3.12 voltage monitor
paktazh
hi guys trying to set my naza Voltage after voltage monitor calibration trying to enter the Voltage it does not get red and does not allow me once i got succeeded and entered everything I thought it saved it automatically after pressing it which it turned to black but when i reconnect my naza i seen again that it is changed to 11.55and11.10 does any one else had this problem
PeteDee
Mr take no prisoners!
Not specifically but I am have a hard time getting my voltages set so that I run down my packs to around 20%.
Pete
OneStopRC
Dirty Little Hucker
Turn that volt monitor off and get a battery monitor and beeper, that voltage monitor in my eyes is worthless. For $6.00 you can get a programmable beeper which shows the volts of your cells, mine works great, I have better flight times also.
I turned mine off for a lot of reasons, the main one as my F550 is heavy, when the battery level got to second stage, my F550 would drop from the sky like a rock and hit the ground. Naza can't handle the weight and certainly does not adjust its decent very well.
Something like this should work. http://www.ebay.com/itm/Apex-RC-Pro...adio_Control_Control_Line&hash=item33828583fe
CrashMaster
Deanalot - exactly what I use. but I use it along with the NAZA voltage system.
I use 3s 6600ma Lipos and set the first NAZA level quite high, 11.8v, so you get more warning and the auto land very low 9.9v with a load drop of .8v. This sets the two levels at 11v and 9.1v under load. I than use the Lipo alarm, the same one you show on e-bay, at 3.5v to 3.7v per cell dependent on packs - this is under load so the actual at rest voltage is 3.6v-3.8v per cell. The outcome is that I get a visual warning and about 60 seconds later an very loud and rude audible warning that I need to land. This means I get about 60 seconds to land.
Again my F550 is 2.5Kg so at the top end of it's MTOM and draws .8v under load. Unlike my X650 which only pulls 0.3v to 0.4v and weighs the same and still has the ability to lift another 500g before exceeding it's MTOM.
Although I have gone back to the old firmware because the F550 will not fly at all properly with 3.12: will not hover at 50% throttle, very unstable, and quite frankly has instilled no confidence to me at all.
