iOSD problem
This has happened about 3 times now since i purchased the iosd mark II which is 3 1/2 months ago. I'll start everything up and i'll notice right off that the distance reads 0 and battery level reads 16.2 or so and they do not change at all. When it first happened I had to land it and now i do not even take off until i get readings as expected. I disconnect the batt and reconnect and then it's all good to go.
Does anyone else experience this?
This happened to me for several months; all the screen data was correct apart from the distance from home. The battery level, in my case , seemed to be functioning. This was the case for both the iOsd MkII and the odd Mini - no distance from home. Then all of a sudden the problem cured itself. After numerous flights it appears to be going well until, one day recently, the iOSD Mk II packed up completely; a problem which is unheard of apparently.
The only info I can offer therefore is that the distance from home data must be a common issue, it may right itself eventually but that is not guaranteed.
