Intelligent Mode does not stop motors in 3 sec
fvg007
I have the F550 with DJI motors and ESC and Futaba 8J Tx with R2008SB Rx.
Running S.bus setup
Follow manual setup assistant and calibrate Tx.
But it suppose stop motors - After CSC and if I don't push throttle after motor start.
This also leads F550 cannot hold fix height if I take off anyway.
Any anyone can help...please :upset:
tstrike
pendejo grande
That almost looks like it's in manual. Are you in atti mode and getting a slow flashing yellow light?
fvg007
fvg007
I notice when system won't stop the motor after CSC within 3sec without push power, something wrong with the NAZA!
tstrike
pendejo grande
shouldn't your throttle slider be all the way to the left when the sticks are calibrated and tx throttle is all the way down? You're hitting the "write" button after you make changes? You did the walk around in a circle business to calibrate the gps? Just throwing things out there since I don't have Futaba gear.
fvg007
Yes...I just center throttle to show it is all stable and green in centre point.
GPS calibration done without any problem as well.
Just somehow I wonder if it is firmware problem, however, I did try to setup on my 2nd computer which turn out same result.
fvg007
It really looks like to me system cannot tell throttle position. Unless I really miss something in the Tx calibration part which look very straight forward to me!
