Installing Naza GPS v2
JCcreative
Im trying to mount the Naza GPS unit with the provided little stick and metal bits, but the stick is so loose in the metal hardware, it just freely spins around.
How do you make the fit tighter, so you can point the gps in the right direction?
Thanks in advance.
Thanks in advance.
I had the same questions a week ago. I was told to glue both ends.
wrap paper around the ends of the stick and jam it in the hole, it will tighten it so it doesnt move freely but it will still allow u to turn the gps head if necessary
Find out if you need a small offset (depending on your location) then send it home with epoxy or crazy glue like JG said
JCcreative
Thanks for all the tips!
I used the paper method for a while, but i have now bent the metal in a vice just enough to hold the rod firmly. Its still removable, but it wont pivot while in flight.
