platform: Pixhawk, CSGShop Neo-M8N GPS (same error with 3DR LEA6H GPS)
If anyone knows or has an idea what may be causing these INAVerr, I'm all ears.
I've posted at DIYDrones, RCG and APM Copter support. The latest reply from Randy was:
I should be more clear. The PM message's long-loops error is a red-herring. The inav errors are likely a real problem. I don't know why in your logs it keeps having problems. Rob apparently looked at your logs and the GPS seems to be updating at the correct rate.
Nobody (literally) has stated what it is exactly, or what can cause these errors. It shows up in Auto Analysis as looping (APM Speed error), but it has been determined that is a false positive.
The real problem is the INAVerr quickly passes 255 and stays there. What are the symptoms? Twitching while in any GPS mode (poshold, Loiter etc.), momentary loss of control. Yet, sometimes it seems to smooth out and will hover 5ft off the ground perfectly.
I haven't yet uploaded the text to put in Excel, but the gaps in data are obvious in the top picture below. It looks like timed events; not random. Poor wiring is not likely because the time curve is linear (no interruptions). The bottom picture was a mission flew last year not exhibiting the problem.
In the meantime I've ordered one of these to test: http://arsovtech.com/?lang=en
