Improving Lift without Costing Flight Time
Hi Friends - currently flying a fully loaded Flame wheel 450 (CCTV) with the stock DJI 2212-920kv motors. I have a set of Guai 2412-960kv's available too. Would there be any noticable advantages to swapping the 920kv for the larger 960kv motors? The stock DJI 30 Amp ESC's should be able to carry the current load too (right?).
matwelli
you will have more lift, but also more weight, flight times may stay the same if the weight increase is small, and the bigger motors run more efficient/cooler
just try it out, you have nothing to loose apart from an hour or so of time
