GotHeliRC
http://gothelirc.com
$66.95
http://www.gothelirc.com/products/3...itor-with-built-in-58ghz-32-channel-receiver/
Perfect for you or your buddies to check in on the race. This economic FPV monitor is packed with a super bright 4.3"" LCD screen, 5.8GHz 32CH video receiver, and built in 2200mah rechargeable battery.
Excellent choice for your FPV monitor, or as a secondary backup screen for your friends to watch. The 500cd/m is plenty bright for outdoor applications where you need a bright screen, and the included sun shade will help keep unwanted light off the screen, reducing glare. The integrated rechargeable battery keeps your FPV groundstation compact and easy to use. The Hyperion 4.3 FPV monitor features 4 bands and 32 channels with easy to use push buttons and an auto search feature.
This monitor will not go to a blue or black screen when video signal is lost or static. Perfect for an FPV application where you don't want your screen to go blank when the video signal is weak.
Features:
Features:
- 4.3 Inch, 16:L9, Sunshield protection
- Four bands, 32 channels with Raceband
- CNC Aluminum bracket for radio mounting
- Vivid colors and bright screen
- One key automatic frequency search
- 4.3" LCD Monitor with 5.8GHz 32CH (Raceband) receiver
- Built-in 2200mah LiPo rechargeable battery
- 5.8GHz Circular Polarized Cloverleaf Antenna (RHCP)
- Removable plastic pop-up Sun Shield
- Instruction Manual
- Screen Size: 4.3 inch
- Screen Type: TFT LCD screen/long life
- Resolution: 480x272 pixels
- Aspect Ratio: 16:9
- Brightness: 500cd/m2
- Video Format: NTSC
- Input Signal: AV
- Working Voltage: 5V
- Power Consumption: 500mA
- Working Status OSD display: Battery indication, Channel inaction
- Built-In Rechargeable Battery: 2200mAH
- Working Time: 2 hours
- Dimension: 122.7*80*14.5mm
- Sensitivity: -90dBm
- Frequency Range: 5645MHz - 5945MHz
- Channel: 32 channels (with Raceband)
- One-Key-Search Frequency: Button control
- Audio: 6.0MHz - 6.5MHz
- Band A: 5658(CH1), 5695(CH2), 5732(CH3), 5769(CH4), 5806(CH5), 5843(CH6), 5880(CH7), 5917(CH8)
- Band B: 5740(CH1), 5760(CH2), 5780(CH3), 5800(CH4), 5820(CH5), 5840(CH6), 5860(CH7), 5880(CH8)
- Band C: 5865(CH1), 5845(CH2), 5825(CH3), 5805(CH4), 5785(CH5), 5765(CH6), 5745(CH7), 5725(CH8)
- Band D: 5705(CH1), 5685(CH2), 5665(CH3), 5645(CH4), 5885(CH5), 5905(CH6), 5925(CH7), 5945(CH8)
