How low do you go?
Doing a bit of data gathering with our new AD6 HL with a view of setting up our various voltage alarms. Running 2 x 5,000 mAh and logging flight performance with the data collected on the Powerlab 8 and the DX8. So the big question is what do you consider the lowest voltage you would run until?
rwilabee
Dave....
Does that work better than figuring out how long you can fly so you still have about 20% left in the battery.
Rich
RTRyder
Merlin of Multirotors
What I usually do is fly in increasing increments of time and check the charge left in the battery afterward. Generally start off with a 5 minute flight, check the packs, swap to another set of batts and fly for 7 or 8 minutes depending on where the first set were at, the goal being to find out how long you can stay in flight before hitting the 80% discharge. Once I know that I set the TX time for a minute or two less than what it takes to get to 80% discharge so I have time to return to the takeoff point and land with a bit of a safety margin. Occasionaly I find the multi a good distance away or fighting the wind trying to return to takeoff so it's nice to know I'm still within battery capacity as the timer goes off and I start the landing process. Also a good idea to set the voltage warnings maybe a bit below this point so you have a secondary warning if you stretch the flight time out a bit.
rwilabee
Ken that is the way I have been doing it minus the voltage warnings in my WKM. I have never turned those on.
Rich
