How do I mount this gear
38super
Hi All
Need some help on this. I have a f450 wheel and having trouble mounting my X468 fame gear st
Assembling it was easy. made for GoPro. When I looked at finished picture with a f450 I noticed
the quad was set up 90 deg differently then a normal build as demonstrated in dji web site.
In this configuration mounting would be easy holes line up well .Does anyone else have this set up that could give
advice on mounting. I was thinking of just using double sided taped with some hardware support. May help with any vibration
but not sure I would trust just tape
Will
PeteDee
Mr take no prisoners!
I gave away my X468 frame I thought it was so bad but from memory you are best to have the lower plate extensions facing front and rear and then it goes on fine, just undo the power plate and spin it 90 degrees.
Cheers
Pete
38super
Cheers
Pete
Hi Pete Well I am new to this so you have to try the bad so you know what good is . I made a few mods to it was going to give it a try when my Spectrum ar8000
started to act up . Would show hold (red led) every time I shut Tx off. BUMBER. I did what you said and work like a charm . For what ever reason RC-Drones put it together
for me and set it 90 deg off .going to email them and ask why . These things are easy to put together and they managed to screw it up Later Will
