wearypanda
I need your help please. I am running out of ideas here.
I have a Z15 GH2 which I purchased as used. The Zen seems to be OK, I have made sure that it is properly balanced. It initialises as it should and I have no reason to believe that there is a problem with it.
The WKM is running 5.22. It was bought new and I am using a V2 IMU. I have had problems with this unit. Although it flies OK, I was not able to use the upgrade to 5.26. With 5.26 installed all I get is flashing green (and maybe yellow) light and the GPS does not engage. The compass calibrates OK most of the time, but as soon as the white light goes off the green flashing lights start up again. So, I have resorted to downgrading to 5.22. It seems to work fine on 5.22.
When the Zen is connected to the WKM I am getting about 8 degrees total roll and tilt drift through 360 degrees of pan. This happens whether I pan the gimbal through 360 degrees or the Hex (suspended), with the gimbal holding position. Also, when the Zen initialises it is not completely level in tilt or roll. Pointing forward it is typically about 3 degrees out in tilt and 1-2 degrees in roll. I have tried both the Mk2 and Mk1 IMU's and they behave the same.
If I initialise the Zen without it connected to the WKM it levels perfectly and, when the Hex is suspended and rotated the Zen holds roll and tilt to within 0.5 of a degree.
So, the finger of suspicion has to be the WKM sending crap data to the Zen. Or could it be that the Zen has a fault which only shows up when it is receiving data from the WKM?
Any help would be greatly appreciated. I really don't want to have to send both my Zen and the Wookong M back to DJI. That puts me out of action for months potentially (given how slow their service is) and I am trying to earn a living using this rig.
Can anyone help?
Sorry for the long post....
Can anyone help?
