Help! Tarot 5008 340 KV esc recommendations
Hello,
I have been doing some research on a descent esc to use with my tarot 5008. I have read quite a few post, most that are saying they are using hobbywing 40 amp esc. I have not used the hobbywing brand esc before and wanted to know if it is a good esc? programmable? experiences with them? I have been using detrum 40 amp with bec for my bicopter, which works well. Afro 30 amps for my quad which I like those but they do not work on 6s, and original simonKs on my tri, which are ok.
The biggest problem I am having is that it needs to support 6s with 40 amps. I have also read that a lot of the newer esc run at a higher refresh rate for multicopters. Any thoughts on the need for that?
Any and all help would be greatly appreciated,
Don
